Hi,
I can't find much consistant information about what Amp fuse/breaker to use when installing a Dual Battery Isolator/VSR in my 120. It is a 2005 petrol model.
It is a Kings isolator but seems to be from the same factory as all the other isolator kits. Kings reccomend a 50 A fuse for the 120, but KickAss supply a generic wiring kit with an 80A fuse. I have seen some installs on line with as high as 120A fuses.
Can anyone with an isolator install please let me know what Amp fuse/Breaker you are using or reccomend?
Thanks very much.
Thanks very much.
