after a couple of hours on the net tonigt with not luck, i'm asking here.
it seems as though i have no boost, as a result of the stepper motor not working. i'm assuming.
the prado is super slow, like a 2.4L diesel hilux, and won't rev any higher than about 2000-2200rpm.
scan gauge shows -3.5 psi boost, and the stand alone boost gauge shows zero.
free revs on the slow side, but will do over the 22oorpm under load. top speed is about 80-90km/h.
it just feels like a NA trying to push 2.6t on 33"s.
i have checked the turbo control module under the glove box, which seems ok. the scanner doesn't read/log any falt codes, so i can't narrow it down to anything.
nothing around the turbo seems odd, and no wires are melted or unplugged.
i've disconnected the batteries for about an hour, then re-connected them in hope that would have reset things. still no different.
any help is appreciated, or if there are any other things for me to check, let me know.
thanks in advance.
thanks in advance.
