Pre D4D motor EGR blank
  • Pre D4D motor EGR blank
    Gday prado people.. I was wondering whether anyone has put an EGR blank gasket or something on the pre D4D motor? If so is the difference noticeable?
    Yes. In what way do you expect it to be different with one fitted?
    If you mean an intake manifold that remains clean after the mod (and cleaning of the manifold at the same time) then yes it is..
      Hey bud, im a mechanic so I understand that the intake will be cleaner and all that. I meant as in did you get any dtc codes or anything any MILs? Did it run better or worse? Effects on the fuel consumption? Would you recommend it?
        If you only plug the vacuum line or use a blanking plate then you won't get any codes. It's only if you unplug the position sensor or either of the controlling VCV's that you will get a code or check light.
        If you plug the vacuum line (easiest method, ball bearing in the line) it can be seen on any real time scanner/analyser as the EGR lift stays at zero percent all the time.
        Makes no noticeable change to performance unless the EGR had a problem to start with.
        Mick
          And you would want to do this;
          http://www.pradopoint.com/showthread...-throttle-body
