Bad Engine noise/Oil light on. HELP!!!
  • #46
    Originally posted by FWD17 View Post
    TurboD4D any luck getting the Prado back on the road? I'm interested to know how it runs?
    FWD17
    Its all back together and in the car again. Starter motor is full of mud I think, so had to towstart it today.
    Runs ok. I think one of the serpentine belt pulleys is bit dirty as it sounds a bit noisy. The motor runs smooth at idle. The engine check light is on and I think (hope) its in limp mode as it wont rev past 2000rpm.
    I have a short video of it running i"ll upload later
    TurboD4D
    • #47
      i'm not certain , but do you have to get the new injectors PIN coded to the engine ECU for the check engine light to go away?
      • #48
        I never ended up putting new injectors in it.
        I did find that one of the electrical plugs from the top of the fuel pump had come loose.
        Have pushed that back on nice and tight.
        I cant start the car now as there is an electrical problem somewhere. I have no idea about that stuff.
        All dash lights work but no click from starter motor. I have power to the big bolt on side of starter motor.
        I have checked 7.5amp fuse under steering wheel. It has power when key is in start position (Im guessing thats right)
        I don't have a multi meter to check relays so Im now stuck.
        Im going to push start it later to check if loose plug was reason for limp mode.
        Any suggestions on the electrical fault would be appreciated.
        • #49
          Do you have 12v to the solenoid wire on the starter motor when the key is turned? If you don't have a multimeter or a spare pair of hands then remove the solenoid wire and use a test light. Set your phone on video and sit it pointed at the light then switch it on and off a few times with the key. If you are getting power there then you have starter motor issues. If not most likely relay.
          • #50
            Dare I say, a check engine light will have a code that needs to be read so your not "guessing" what's at fault..
            Might be the first place to start, could be something simple causing it to not start..
            then again, might not be too..
            Multimeters can be found new (jaycar etc) for like less than $40..
            • #51
              So I pulled the starter motor out and pulled it down and gave it a good clean. Works great now.
              The cars no longer in limp mode (must have been that loose plug). But engine check light still on.
              I will reset that and see if it comes back suggesting another fault.
              Turbo doesn't seem to be working. I noticed just before engine spun its bearings that it had stopped working, had a look at it while it was out and it seemed fine mechanically. Ill have to check some vacuum hoses had one fall off once and it caused Turbo to stop working.
              On a good note it goes in to Toyota on Monday for a Free Dash
              • #52
                Popcorn or not,
                You get 110% for getting in their & having a go.
                Can you put up some pictures of the engine, vehicle, mud, you working on it.
                I'd like to be able to visualise.
                • #53
                  So this is the culprit. (this is my mate having a go) He also did his alternator.
                  https://youtu.be/_zKOAP6Ig9g
                  I got stuck in here and had to be towed out. Was sitting in there for about 5 minutes.
                  • #54
                    Couple of pics of job
Name:	just removed.jpg
                    More to come
                    • #55
                      Wow that is a car wrecker!
                      Looks like some awesome fun.
                      But Car wrecker, don't do it.
                      Cheers, for that.
                      • #56
                        A couple more
Name:	head bottom.jpg
Name:	Head back on.jpg
                        5 of the bucket shims fell out when cleaning the head.
                        WOW!!!!! What a job finding what order they went back in.
                        TurboD4D
                        • #57
                          Finally putting it back in.
                          Ill upload a video of it running soon.
                          • #58
                            Double post
                            • #59
                              Ok so here is the video of the motor running without the balance shafts
                              https://youtu.be/qLJ_Dz7OIJs
                              • #60
                                I cant tell the difference .
                                have you found the turbo and check engine faults?
