Fuel gauge
  • Fuel gauge
    Ran out of fuel with the gauge,showing 1/4 full with the 90 litre light on, filled up 177 litres,now the gauge is stuck on full after doing 400 kys ,your comments please John.
    Bit more info about the vehicle would be a good start
    i.e. it's a 120 presumably as you've posted in the 120 section but what year (might help someone who's had similar problem say with some certainty what it is),
    how hard a life has it had,
    how long you've owned it.
    having said all that it could be the sender has given up the ghost after 15 years (or is sticking due to age) or there could be a wiring issue
      Sounds like new fuel sender is needed.
      My Rig Build up
      sigpic
        Thanks diesel69& Amts ,2007 120 D4D diesel had it since new with 306 thousand kys on the clock ,just to add to what is happening the gauge finally started to register after 550 kys will see if the 90 litre light comes on when tank gets down,set tha trip meter,know I am getting pretty low at about 1500 kys mostly in city driving,maybe sender unit.
          Just go with the trip meter if the fuel sender continues to play up and you don't want to spend money on it just yet. But you do have to fill up to full every time.
          My Rig Build up
          sigpic
            That was my plan thanks amts
              Just an update on my fuel tank problems ,ran out of fuel again the 90 litre light,came on for about 50 kys,& the trip meter gave me a reading of 1010 kys ,filled up would only take 80 litres,which took about 20 minutes to fill,read plenty of posts about this still not sure what is going on ,2007 D4D Diesel Prado with 3006 thousand kys on thr speedo,all comments appreciated.
                That is a symptom of a blocked between tank fuel filter.
                My Rig Build up
                sigpic
                  Thanks Amy's ,changed about 15000kys ago,could not get a Toyota one used a Ryco,have always used genuine parts ,as I can get them at trade,less get,will change it out in the next couple of days ,hope you are right, thanks mate will keep you informed.
                    Fuel filter not blocked,posted in another fuel thread,wondering if I can get the fuel pump out without taking the tank out.I read somewhere that you can get at the fuel unit under the rear passenger seat,not sure if you can take it out this way or drop the tank ,thanking you John.
                      See here https://www.pradopoint.com.au/forum/...out=&styleid=3
                      My Rig Build up
                      sigpic
                        Thanks amts,yes I have seen that post,was hoping you might be able to take it out through the opening in the floor, thanks mate.
