Turbo Replacement for 120 Series D4D
  • Turbo Replacement for 120 Series D4D
    Hi Guys,
    Just thought I would post a message on here as I have been a member for a long time and have had some great reads on this forum. I have just noticed that there is oil leaking from the front housing of my Turbo, after getting it looked at I have been told the Turbo needs replacing. I have just clocked 200,000 kms and have noticed the Turbo has been wining which prompted me to check.
    Any ideas on where to go and what others have done, as I have been checking the forums but couldn't find any threads relating to my particular issue or what others have been doing in this case. I am thinking that if I have to replace it may as well go for an upgrade. Any suggestions would be great and who is the best guys to see in Perth. I have been told United Fuel Injection is the place to go and the Garrett turbos are a good upgrade for the CT20 ?
    Thanks for your help, apologies if there is already a thread on this, but I couldn't seem to find it.
    Cheers !!
    I use allied turbo and diesel wangara, they should sort you out, not cowboys
    They run hiluxs as work utes so know all about the d4d
