Noisy Belt Tensioner Pulley
  • Noisy Belt Tensioner Pulley
    Gíday lads n ladettes,
    Iíve got a noisy belt tensioner pulley (a/c belt) on my 120 its on a 1KD-FTV engine. Now my issue is Iím having trouble finding just the pulley/bearing as shown in the photo. Iíve looked around and all I can seem to buy is the whole assembly (tensioner, bracket, pulley etc) I just want to replace the pulley/bearing if possible.
    can anyone point me in the right direction?
    thanks for your help.
    Adz.
    G'day Adz88
    ebay will be your friend for this.
    hope this helps
    Tony
      Dayco ep308 $85 at sparesbox
      also ep 258 ep 259
      and the belt is 7pk1640
      see if they all need doing together
      cheers
      mike
      White 2010 gx diesel auto, bilstein shocks 50mm lift king springs, tjm steps, warn 9500, lt265-65-17 bfg atko on steel rims. Racor 230R10 filter
      Adelaide based
        Adelaide based
          reddevil25 Is that photo you put up off the sparesbox page, just having trouble seeing the photo clearly?
          I did come across that page just havenít had the time to sift through and see if it had the droids I was looking for.
          Got the belt the other day and the other two pulleys seem to be in pretty good order.
          thanks heaps for the good direction Iíll have a closer look tomorrow.
          BigT01 eBay has been anything but my friend in this instance mate. Thanks though
            Itís from the Dayco catalogue app
            sorry didnít load well here so itís hard to read.
            type in EP308 on eBay and sparesbox have it listed on there currently 95. I bought when they had a sale on.
            try your local repco or super cheap , May match
            Adelaide based
              Gates Australia also supply idler pulleys and tensioners.
                Thanks for the input. I found the part on sparesbox.
