Fault Code P1229 - What should I do?
  • Fault Code P1229 - What should I do?
    Hi all,
    Tonight I got fault code P1229 on my 1KD Prado 120. On reading past posts it seems like this is something to do with the fuel system - maybe the suction valve? I am wondering if it could possibly be dirty fuel? I filled up at an unknown independent service station today and then drove another 700 km. What do people suggest I should do first? Really want to get it sorted - this was the first day of a nine week trip to Cape York, stopping in Brisbane on the way for my daughter's wedding!
    2008 D4D GX Auto, OP2 (traction/cruise/climate control), ARB deluxe bar, DominatorX winch, dual batteries, Whitey's 50mm lift, 265/70/17, UHF, King's 7" spotties, trans cooler
    Should have added - injectors were changed when I bought the car, 25000 km ago. It's now at 195000 km. A few weeks ago I pulled off the egr and intake manifold and cleaned everything, and installed a blanking plate for the egr with a 7 mm hole. Have had no codes, no issues till now.
      Hi mate, couple of things I found
      P1229 Code - General. ... OBD-II code P1229 represents a problem with the pressure of your Toyota's fuel system. ... The fuel system on your Toyota is controlled by the fuel pressure regulator and most problems with over fueling will come from this part, or wiring to it.
      also there was this
      https://www.pradopoint.com.au/forum/...t-code-d4d-120 which points to fuel pump failure
      Hope you sort it.
