I'm going to replace the Timing Belt, Water pump & Thermostat on my 05 1KZ Prado. Done plenty of this type of work before, but wanted to know if it is necessary to remove the Radiator completly to do this on the Prado? Read a couple of different walk-throughs, and some say yes and some say no?
1KZ Timing Belt & Water Pump Replacement
No it's not necessary there is plenty of room, but it's only 4 more bolts and the bottom hose and it's out - so why wouldn't you?Silver '04 KZJ120~Manual~GXL~Dobinson/Kings lift~Custom valved Ironmans~Detroit Locker~Endless Air~X9 Superwinch~Madman EMS1~TJM Dual Battery~Rhino Roof Tray~120W solar panel~Foxwing awning~Bushskinz UVP~Long Ranger water tank~Bushman fridge~Steinbauer P-Box~Beaudesert 2 3/4"~Airtec Snorkel~TJM Sliders~Prico Boost Gauge~BFG-KO2s~TPMS~GME TX3420~Front and Rear Cameras~Ultimate Camper hanging off the back!
How old is the rad then? I would take it out just to inspect it anyway. Even at 120K mine had the fins hidden behind the aircon condenser rotting away. Replaced it with genuine Denso off Ebuy. Cooling system deficiency will kill your cyl head faster than anything else. Injectors, glowplugs? The list goes on
