Fan Belt Tensioner Pulley Removal
  • Fan Belt Tensioner Pulley Removal
    Hi,
    I'm up for a new fan belt tensioner pulley. Is the bolt thread conventional (anti clockwise to remove) or reverse threaded?
    Thanks,
    2008 GXL D4D + Option Pack 1, Safari snorkel, factory alloy bar, dual battery system, Lovells TFR-118/TRR119 Springs, Bilstein Shocks, Prodigy P3 brake controller, factory tow bar, Orac coupling.
    Don't worry, got it off. Unfortunately, changing the belt, 2 idlers and tensioner pulley haven't solved my squealing issue. I'm the sound seems to be coming from the tensioner area. How do the tensioners squeak? I thought it was just a round hub on a coil spring.
        Run it without a belt? Any squeak? No.. Check all pulleys and air con/ p-steer, Alternator..
          No squeak with the belt removed. Interestingly enough, when the when the squealing noise stays for a while while idling the alternator cuts out and voltage drops to 12.3V. The voltage goes up to 14.1 when driving. Not sure if the alternator pulley or bearings are suspect.
          The new fan belt pulley I installed has left a thin trace of grease. Will have to keep an eye on it for a few days to see if the leak stops. I hope it's just an initial weep of grease and no a faulty pulley.
            Could be the alt pulley as itís one of the overrun type .
            they can be replaced. About $82 plus a 17mm hex to undo it if you havenít got one
            cheers
            mike
            oap008 is the Dayco for 120 diesel
            White 2010 gx diesel auto, bilstein shocks 50mm lift king springs, tjm steps, warn 9500, lt265-65-17 bfg atko on steel rims. Racor 230R10 filter
            Adelaide based
              Thanks for that. I had a feeling it wasn't the tensioner. I found the following video. https://www.youtube.com/watch?v=IKMSOlR0RQs
              I've got exactly that same noise intermittantly. I need the engine mounts done anyway so will probably get the alternator, pulley and tensioner replaced in one go. If an alternator isn't too expensive, I'll probably just get a new one. I don't want to replace the pulley only to find a bearing or brush worn in the alternator in a year or so.
