Turbo pressure sensor
  • Turbo pressure sensor
    Hi, I am new in the forum.
    I own an 2005, 120 Prado with 1KDFTV engine (Diesel D4D), the engine lost power and the The mechanic diagnosed the fault as a faulty turbo pressure sensor, the sensor was replaced with a used one and now the engine runs smoothly.
    When I go to order the new sensor I noticed the the one that was installed on my vehicle is P/N 89421-20190 and according the catalog in japan-parts.eu the correct P/N is 89421-20210.
    What is the differences between the two and which of them should be used in my vehicle?
    I believe that's pretty straightforward, use the one that's making your engine run smoothly. If you didn't buy your Prado brand new, you don't really know if the faulty one was the original.
    Also in my opinion, in spite of the manufacturing variations, the values given by the sensor should't really be different.
