Cleaning intake, and I'm now at port cleaning. I need to close the valves to get the crap out, which means turning the engine over manually to close the valves...which means removing the glow plugs. I have no idea when they were last changed and it's done 260kkms. I can't start the engine cos most of it is disassembled, and I don't want to try and remove them without some heat and penetrant. So to hopefully prevent me from snapping any of these plugs:
Can I close the valves and clean the ports without taking the glow plugs out?
Is it possible to heat the glow plugs without the connecting the engine up?
