New to forum after recently purchasing a 07 Prado 120 VX. I have visited Pradopoint in the past, but unfortunately making my first post today due to a problem with A/C.
With no advance warning sign and after consistently blowing nice and cold, this morning the vehicle started up but without any air. The previous night I was trying to solve a problem with the car alarm (installed by previous owner). While searching for the alarm control unit under the driver and passenger side dash I bumped against and tugged on a number of wire bundles.
I don’t have much experience with A/C, but because it failed so suddenly and unexpectedly plus my previous contact with the wiring, I am thinking it could be an electrical/control problem.
Here’s what I have checked so far:
I could be mistaken, but it seems to me that the compressor is not engaging.
Any advice on what to check next (and how) would be greatly appreciated.
I have automatic climate control.
Thanks in advance.
Wess
- removed the lower dash panels on both sides and the interior fuse panel to gain access
- disconnected and reseated all the electrical plug connections in the areas I was working in the night before
- adjusted all the wire bundles and wire harnesses to relieve any strain on wires/connectors
- removed and reseated all the fuses related to air conditioner, heaters, and blowers in both the passenger compartment and engine compartment fuse boxes
- removed and reseated the relay for the a/c compressor clutch in the engine compartment fuse box.
Thanks in advance.
Wess
