Hi, I'm trying to install a VP44 Denso chip to my (pre common rail) 120 Diesel.
From the instructions
For this car you will need to install the system inside the engine compartment on the fuel pump and the trigger signal (grey wire) is to be sourced from throttle pedal connector wiring harness instead from the directly from the ECU.
I've found the connection to the fuel pump wire but struggling to find the throttle peddle connector wiring harness.
I've attached photos of my engine and the instructions, can anyone point me in the right direction???
Thanks in advance
Thanks in advance
