Hi guys.
Got a weird problem with my 120 series thats just started happening.
Occasionally it just wont crank at all. I dont think its the battery, as if you take try a couple of times it will eventually crank as normal and start. At first i thought it might have been starter motor solenoid as it was happening generally when the motor was hot, but it happened yesterday when cold, which makes me lean towards some sort of intermittent electrical fault.
Any suggestions as to things to check?
