Hi all, bought a 2005 120 GXL three weeks ago and got the car back from Toyota yesterday with a list of repairs (and a large quote) to carry out. I'm looking for guidance on:
- the severity of the issues
- approx. cost and effort to DIY vs. mechanic
Pictures and description of issues as follows.
1. Steering rack boot completely gone, inner-rod rusted, and rod-end grease contaminated. Toyota recommendation: replace entire steering rack.
https://i.ibb.co/2Sbf4VK/worn-steering-rack-root-1.png
https://i.ibb.co/crKC7Rd/worn-steering-rack-root-2.png
2. Front diff seal worn and leaking. Toyota recommendation: replace.
https://i.ibb.co/JBgWc0L/diff-seal-worn-leaking.png
3. Front driveshafts covered in grease and boot worn. Toyota recommendation: replace both driveshafts entirely.
https://i.ibb.co/vqSt7ZS/driveshaft-grease.png
4. Timing chain case leak, oil all over driver's side of engine. Toyota recommendation: engine disassembly to replace seal. I spoke to a family friend who used to be a Toyota mechanic and he suggested that disassembly of the engine isn't required and that there's a seal behind the harmonic balancer that may be causing the issue, and that can be replaced quite easily.
https://i.ibb.co/5ssvyBG/timing-case-leak-1.png
https://i.ibb.co/J7zFBcs/timing-case-leak-2.png
https://i.ibb.co/cbDpjZh/timing-case-leak-3.png
5. Water pump leaking, coolant on engine. Toyota recommendation: replace water pump.
https://i.ibb.co/G2CN1mj/water-pump-leak-1.png
https://i.ibb.co/sjzvH4x/water-pump-leak-2.png
https://i.ibb.co/tzmwZZ6/water-pump-leak-3.png
Any help is very much appreciated.
