G'day, just bought the wife a v6 120, went to service and the oil sump plug looks recessed slightly into the pan evenly all the way around the washer? Is this normal or is it a sign the plug may have been over tightened or taken a hit?
Sump Plug/Pan Query
As per the above comment, this isn’t normal, but if the bolt screws out & screws back in fine with no leaks, then it’s of no concern. Maybe it’s an aftermarket bolt too with a shallower hex head on it making it look recessed? Would you be able to post a photo.2005 120 series V6 Grande, 2 inch susp lift (King/EFS combo), 32 inch MT’s, Safari Snorkel, rear diff lock, breathers, Light Force spotlights, UHF, dual batteries.
