1GR-FE Knocking Noise
Broken flex plate?Silver '04 KZJ120~Manual~GXL~Dobinson/Kings lift~Custom valved Ironmans~Detroit Locker~Endless Air~X9 Superwinch~Madman EMS1~TJM Dual Battery~Rhino Roof Tray~120W solar panel~Foxwing awning~Bushskinz UVP~Long Ranger water tank~Bushman fridge~Steinbauer P-Box~Beaudesert 2 3/4"~Airtec Snorkel~TJM Sliders~Prico Boost Gauge~BFG-KO2s~TPMS~GME TX3420~Front and Rear Cameras~Ultimate Camper hanging off the back!
Put some kero/ diesel into engine oil - drive around local street for 20 mins with engine speed under 2k; drain oil, take off sump pan, clean and clean the gunk off every where your hand can reach..: refill with engine oil, do a few more 1000km oil change ( not a typo not 10,000 kn) and monitor oil, soon as it brown up, change….
you will find the noise disappears- if it doesn’t, you have let the situation gone on too fat
Doesnt sound good Sounds very much like a major overhaul coming up,
could be anything from a loose piston skirt to a cracked valve shim. cam bearings WTF
I have a similar ratlle , no where as loud or heavy. Sadly I checked the radiator and didnt screw the cap on straight and it lost a bit of green juice after about 10Ks Luckily I had stopped to hook onto and drag a fallen branch from the road after a fire and heard a hissing noise . Thought it was a staked trye but no it was the radiator hissing through the crooked cap .Walked back to the camp and let it cool of for a few hours , Filled up the radiator with new inhibitor , took 4 litres, so it was very low , now it has a slight rattle and a miss . The engine warning ight comes and goes , a rough idle , but engine warning light goes out above 1000RPM. Also the Oil light comes on and off . Has new oil, even an extra 60MM on the dip stick . Thats what happens when I got it serviced in town , put in about 3L too much but didnt even change the oil or Air filters .. Cowboys , but they knew how to Charge
BTW I have just got this 06 VVTI Petrol and would like to check the Tranny <> is there a bung hole , dip stick push button??<> PICS pls anyone Its my first Auto Toyo the others have been Hiluxes or Cruisers with manual boxes and a bung Hole . DO LOVE the auto , fantastic in sand , if one wheel starts spinning just touch the brake and they all grip/spin together. Can even change gear on the beach, unlike the Hilux that spins and sinks . Autos from now on for me
