Water in headlights
  • Water in headlights
    I have a 2008 120 series. About 3 months ago we had to cross a swolen creek. The headlights were submerged. The car is fine but there is moisture in the headlights. Any ideas how to fix it?
    I had moisture in the fog lights.
    I removed the bulbs for a day and the moisture disappeared overnight.
    If you need to put the bulb back in too early because you need to drive at night just do it again until the moisture is gone.
    Regards
    Michael
      The best way to get water out of lights I've found is to remove the light from the car, and throw them in the oven on a low heat with out the globe's in them. Work's a treat!
      96 3.4 GXL, 2" lift, Poly airs in rear, 32" BFG muddies, Lightforce 170's HID's, TJM rack, Awning, Twine on board shower, GME uhf, Dual batteries & monitor, Storage system, ARB fridge, LED rear lighting, Safari snorkel, Brown Davis bash plate, Ironman winch bar, Runva 11xp winch, Roadsafe recovery points, ARB compressor, Tyre dog monitor, AJ's sliders, Hema hn6. The to do list is getting shorter.
        You can remove the headlight with the bullbar in place?
        [SIZE=1]Cheers Jim.
        [/SIZE][COLOR=#0000cd]
          I have had same problem . Fixed by removing headlamp globe then pumping compressed air into lamp socket area of headlamp for about 30 minutes . Headlamp need not be removed .
