The door guard/trim on the bottom of the passengers door keeps coming loose and flapping in the wind when driving along the freeway, Not sure wether to just squirt some silicone in there and stick it up or should I try and remove it and fit a new clip or whatever hold these in, it looks like the previous owner has already done some sort of glue trick as I can see a big blob that obviously is no longer doing the job..
door guard keeps coming loose
Those clips are a pain. If you take it off get a whole set because they break easily. It may also be the notch in the trim that the clip clips into thats worn so even a new clip may not work. Instead of silicon, use urethane like sikaflex, sticks much better but you need to be neat.Can't we just keep travelling?
Travelling Panelbeater
