Plastic Skirt In Front Tire Well.
  • #31
    Why are so many people missing these inner skirts ??? There is no way they just fall out. I've had three prados none have come away/broken etc and yes all three been off road, all mine ever copped was some scrubbing from larger tyres on the old Prado. They certainly do a lot in protecting the inner guards from being panel beated with rocks and sand blasting and yes to a certain degree water ingress. If you have a genuine Toyota sovereign bullbar and like playing in water then I would suggest a snorkel as the design of the way they cut the inner skirts to match the bullbar layout leads to water being scooped up and fed directly into the air intake and you know the rest of the results.....cheers Steve.
    • #32
      Mine were old and perished. You could tear them easily just with your fingers. At this point, I guess it doesn't take much for them to rip and fall off.
      2003 Prado Grande, Petrol, Auto.
      • #33
        Why are so many people missing these inner skirts ??? .....cheers Steve.
        It happens Steve, especially when they get dressed hurriedly upon the unexpected arrival of a married partner.... just saying.
        MidLifeCrisis
        Out of control poster!
        • #34
          Fair enough Tim never thought about them perishing with age.... Cheers Steve
          • #35
            I had to replace one (front passenger side) as the holes around the studs had fractured. Rough terrain impact maybe. Bought from Toyota at about $130 and had installed during a service at my diesel service place.
            Terry
            Canberra
            • #36
              OUCH!
              • #37
                Wasted money, could have bought thin insertion rubber from CLark Rubber and much more durable and cheaper.
                Did mine for under $40
                John
                • #38
                  I did the same thing. Our neighbours had a 120 similar to mine. Measured the bits and then went to Clark Rubber. Used cable ties instead of plugs and all done for not much. Too easy and cheap. As well, they are still there!
                  2004 Silver GX 4spd auto 3.0 T/D, Safari snorkel, dual batteries (Piranha), Bilstein suspension upgrade & lift, ARB winch-bar, diff breathers, GXL steel wheels and 245X17 Cooper AT3s, Autosafe cargo barrier, Kulkyne side awning & Oztent, Toyota 3 bar rack, Maxtrax, other ARB & TJM recovery gear, Engel and Waeco fridges, Towpro, GME uhf, AMTS recovery points, Tvan
                  • #39
                    templates for making your own
                    Thanks all for the tip re purchasing from Amayama and for the part numbers to use. I have just received mine (shipped from UAE) & total price was $109.87 AUD.
                    In future I will make my own so have made paper templates of the ones i received so can use them in the future. I have also scanned/attached the same as a 3-page pdf file in case anyone else wants to make their own. You would need to print them out on A3 size paper. Sorry about the quality but i had to significantly reduce the file size as this forum has an incredibly small file size limit for pdf files .. what the!!!
                    regards .. Drew
                    • #40
                      regards .. Drew
                      Mate. This is amazing thanks so much!
                      I assume the 3rd panel fits left and right?
                      • #41
                        DrewT
                        Thanks just cut mine out will fit tomorrow
                        Printing cost 54 cents
                        Rubber was just under $30 from Bunnings and have some left over which I can use in a non Prado project
                        2009 120TD Auto, Snorkel, Tow, Soveriegn Bull Bar, Dual Batteries, Rear Suspension Air Bags, UHF, Toyo Open Country Tyre AT II,, ScanGauge
                        • #42
                          Thanks Drew T,
                          Did mine today with rubber from Bunnings. Ordered the clips online and just waiting on those, but will try the cable ties as seem to be better option. Lost my first one when mechanic changed the alternator and he claimed was never on. The others just ripped at the clip.
                          2009 GXL D4D - Auto
