Hi All
My steering has started to wander a bit and been told it could be loose bearings/hubs after 4wd session. What is the correct torque setting to give it a tweak. I plan to pull them apart to check them as both caps are damaged and have leaked. Surface under the hub bolt is rusted so suspect bearings may not be too flash.
Also, do the sell new metal caps (that protect bearings, not trim) or do i just go 2nd hand?
Thanks... Dave
Thanks... Dave
