It seems that the fan doesn't blow as good as it should on hi. Seems likes it a setting short. My work hilux blows a lot better on hi. Is there an issue with fan itself or the controller that is a common thing ?
Check your cabin filter, its behind the glove box in the 150's.
The fan speed out of the centre vents on max on these is around 25kph check it without the cabin filter installed if it is really low you may be looking at a blocked evaporator
That's what I thought Ozpat - the Dave we know has his own speed gun from work to check his speeds.....
