See more
See less
Torque Pro Auto Temp PID's for 120 Prado 2008 3.0 D4D auto
  • Torque Pro Auto Temp PID's for 120 Prado 2008 3.0 D4D auto
    Hi all, just thought I'd share my experience with using Torque Pro on an Android device to display auto transmission temps.
    I'm using a Joying 5.1.1 double DIN head unit, which so far I'm reasonably happy with. Torque Pro came preloaded on it. I ordered an ELM327 OBD2 Bluetooth adapter with the head unit. The first one didn't work properly, and after a few emails back and forth Joying sent me another one, which so far is working fine. I have to say I've been reasonably impressed with Joying's desire to offer good customer service. They're not always that easy to understand, but they seem very anxious to be helpful, and usually respond fairly quickly.
    So I've got a 2008 D4D 120 GX auto. The info on the interwebs wasn't always that clear on which formulas to use for the custom PID's for auto trans temps. Eventually, after trying several versions, this is what worked for me:
    Auto Oil Pan Temp:
    OBD2 Mode and PID: 21D9
    Long Name: Automatic Transmission Oil Pan Temp (or whatever else you'd like to call it)
    Short Name: ATF Pan Temp (or whatever else you'd like to call it)
    Minimum Value: 0.0
    Maximum value: 120 (or whatever other value you'd like for the top temp on the gauge. Some threads suggest 160, but I've got no intention of letting my tranny get that hot)
    Scale factor: x1
    Unit Type: C (for Celsius)
    Equation: (((((E*256)+F)*(7/100)400)/10)-32)*(5/9)
    OBD Header to use: left blank
    Auto Torque Converter Temp:
    Long Name: Automatic Transmission Torque Converter Temp
    Short Name: ATF TC Temp
    Minimum Value: 0.0
    Maximum value: 120
    Scale factor: x1
    Unit Type: C
    Equation: (((((G*256)+H)*(7/100)400)/10)-32)*(5/9)
    This is what worked for me. There are some threads around that suggest a PID of 2182 instead of 21D9, and some threads have A/B or C/D in the formulas instead of E/F and G/H. Couldn't make it work with those.
    When you're driving along you'll observe that the TC temp varies a lot more quickly then the pan temp, especially when accelerating, going up hill, or using the gears for engine braking. When you return to flat steady speed driving the TC temp usually equalises to the pan temp quite quickly.
    Hope that's helpful to someone :-)
    Tim
    2008 D4D GX Auto, OP2 (traction/cruise/climate control), ARB deluxe bar, DominatorX winch, dual batteries, Whitey's 50mm lift, 265/70/17, UHF, King's 7" spotties, trans cooler
    Hey Tim,
    Cheers for that. I did have Trans temp, but it showed the same temp as coolant.
    Shall try it soon and post.
    Tokhi
      Hi Tim, how do you find the sound quality from the unit as well as the speed?
      Are you using the factory speakers or better?
      [B][2007 GXL 120 3.0L D4[COLOR="#FF0000"]D[/COLOR] Auto][/B] [I]Mods:[/I] [COLOR="#DAA520"]Bilstein [/COLOR][COLOR="#0000FF"]Shocks [/COLOR]& [COLOR="#DAA520"]King [/COLOR]2" Lift Springs - 265/70/17 [COLOR="#3366ff"]Cooper [/COLOR]AT/3s Tyres - [COLOR="#FF0000"]ARB [/COLOR]Deluxe bullbar - LED Spotlights & Worklights - Snorkel - [COLOR="#008000"]BushSkinz [/COLOR]bash plates - 2.2m Alloy Overlander Full Rack - 2.5m [COLOR="#8B4513"]Wanderer [/COLOR]Awning - [COLOR="#FF0000"]GME [/COLOR]TX3120S UHF & [COLOR="#FF0000"]GME [/COLOR]AE4703 6.6dBi - [COLOR="#FF8C00"]Milford [/COLOR]Cargo Barrier - [COLOR="#FF0000"]JVC [/COLOR]indash DVD - [COLOR="#FF8C00"]Maxtrax [/COLOR]- Pulling a heavily modified [COLOR="#3366ff"]Jayco [/COLOR]Dove Pop Top Camper
        Hi Killswitch, sorry for not responding earlier - I've been overseas. I find the sound quality fine, using the factory speakers, but I'm not much of an audiophile, so I expect I'm more easily satisfied than some :-) The std app for listening to music is fairly basic, though - it would be nice to have a better interface than Joying provides. I think I read somewhere that others have managed to install better apps for it, but I haven't bothered. Tim.
          Cheers Tim. Good to know.
            Hi all, I have 01/08 D4D. My readings display as zero on both custom PID's. Any suggestions?
            I have tried changing the letters in the equation as Tim suggested but nothing.
            The only other trans temp PID equation I can get to work (method 3) only shows the same as coolant temp.
            Thanks, Wayne.
              Thanks very much for the info Tim. It appears to be working OK on my 2005 V6 Grande.
              Are they any other useful PID's that anyone's aware of?
              Stuart
                Ok for what it's worth, the info provided above by ziggle worked on my '05 120 petrol version too (his is a diesel), tried a few other custom PID's before I managed to get his going in my car, the in car values are different too which suggests the formulas are correct. Had always hoped to view trans temps while I tow a heavy tandem trailer interstate in 4th, now a reality. Will watch temps now to understand what is going on in there.
                +1 to you ziggle, nice work.
                  Vitelli, which OBD adapter are you using? The 3 different ones I have ordered all show trans temp and coolant temp as the same figure.
                  Thanks, Wayne.
                    wapehawima OBDLink MX with bluetooth, lashed out after buying one of the cheaper chinese units that didn't work out. This one works fine.
