Anths Prado Diesel 1KD-FTV D.i.y service tips
    More tech tips:
    You should clean the MAF sensor when changing the air filter.
    More often when in dusty conditions.
    Whenever you have a symptom, check the basics, like blowing black smoke, or using too much fuel, even rattles to name a few. Could be the cause or a contributor.
    The MAF is on the clean side of the air box, so how can it get dirty?
    They do, so look after your filters.
    One other tip, I use grease on the seal on off-roaders. It definately reduces dust.
    Cleaning the MAF:
    Carefully unplug, don't pull the wires.
    Remove 2x Phillips screws. Put aside.
    Carefully withdraw the maf from the box & inspect.
    One is the air intake sensor you can easily see & other hot wires are hidden. Shine a light & you will see.
    Don't let anything touch them.
    Toyota procedure is to use only compressed air to blow clean.
    We use crc brand maf cleaner, do not use other products. Do not let anything touch the sensors wires.
    Once done, as per directions on can, blow dry with compressed air.
    Wipe out the hole on the air box.
    Put a tiny bit of Lube on it.
    Check the o-ring on the maf looks ok, if not replace.
    It should easily slip into the box if you have lubed it nicely.
    Put 2 screws back, just nip them don't be heavy handed & pull the plastic threads out.
    Plug in, your done.
    Share it like it, because it's simple & important maintenance that many techs don't do.
    Best to have correct signals getting sent to computer.
    Anth.
    Can you add the oring size and TOYO dont sell them.
      Mine went on my V6. The local mechanic had a box of O rings from which to choose. Cost next to nothing.
        Don't know the size. But best not to break them :-)
        Sorry.
          Check & clean your map filter
          More tech tips:
          Clean and inspect your map filter.
          As pictured.
          The part number is included.
          If you see oil running down, it may be cracked. Naturally replace it.
          If it looks ok spray carby cleaner through it, till it flows clean, then blow dry with compressed air.
          It's important this is clean & not leaking so the correct signals are sent to the computer.
          If you notice increased fuel use or it's a bit slow or sluggish to boost, this may be your issue or a contributor.
          Often not checked in standard service centers.
          Hope that helps,
          Anth.
            Hi all,
            my O - ring on the maf sensor is broken. Phoned Toyota who do not sell as a part, and only have the whole unit at a couple hundred bucks.
            Presume I will need to take it in and match it up at a parts supplier (Cov's or Veale's here in WA) ,before I do has any else needed to buy one and if see where did you source it from.
            Thank you
            Mark
            2009 GXL D4D - Auto
              Originally posted by Mark120 View Post
              Hi all,
              Thank you
              Mark
              Its an O ring.. Any O ring supplier, CBS etc will have something..
                I know itís an O ring I was asking if any one has actually replaced one and where they got it from.
                You would think any O ring supplier would be able to match it, 5 stores this arvo and no one had one. They are thinner than standard rings so will keep on looking.
                2009 GXL D4D - Auto
                  CBS has them, Partouq, Toyota, Amayama. https://www.amayama.com/en/part/toyota/9009914141 Same as Subaru ones too. plenty available around Aust.
                    Got an O ring from Toyota parts department for the MAF sensor when I first started cleaning the unit some moons ago. Just a precaution looking at how thin it is, however the original is still going strong.
                    1GRFE Engine, but my point is the availability from Toyota parts if you deal with an interpreter that knows thier stuff.
                    cheers
                    Troy
                      Nice work mate
                      11/06 kdj120 gx wide body auto
                        I come across this thread and took a look at my vacuum filter. As Anth noted it was cracked so I ordered a new one. While I waited for the part to arrive, I cleaned the old one and used nail polish (not my own lol) to seal the cracks. I noticed straight up more low down power, better torque and quicker response from the motor. I'm not talking a huge improvement, it was supple but noticeable. Note my vehicle is 9 years old (147,000 km) and noticed it was getting a bit doughy in the last few years. Next week ill be checking the throttle body for carbon build up.
