Keys
  • Keys
    I have been reading my way through many posts regarding keys but can't find the answers I'm looking for.
    We've just bought a 2005 VX & were only given one key, which seems to be a "without wireless" master key, after checking the manual. On a side note I can't believe a 2005 model car came out with this type of key.
    So we'd like to get a spare, after searching the web have come across a website that sells a transponder key for $20, but I'm getting a bit confused with all the talk on programming them etc. Can anyone shed a bit more light on this for me.
    Also is it possible to get a wireless master key that doesn't involve spending massive $$ through Toyota. The manual shows that the car the both key options. Or I guess another option is aftermarket wireless??
    Sorry but I'm a bit overwhelmed with info at this point. lol
    I'm no expert but have all 4 keys for mine but have been doing a little research to get another remote.
    So you have no remote key with buttons ?
    You do have a plain black toyota key that operates central via door lock and starts car ? (Ie a master key that has a chip in it but no remote ?)
    There's a mob on fleabay called amalgamated locksmiths who get goid reviews in other threads on here. They have a bricks and mortar shop in newstead. Might be worth phoning them and then the day trip as they do 2 remotes for around $80.
      Mr minute can also help you out at any shopping centre
        back on a PC so can copy links
        https://www.ebay.com.au/itm/50171-To...53.m1438.l2649
        no affiliation - just read some other threads recommending these guys
          Got mine from them last year and then got it cut locally. Programmed myself using their instructions from that link as the key cutter wanted..........$250........... to program it for me. Took 2 goes to get it right but no problems since.
            If you only have the valet key (i.e. does not have the lock/unlock buttons), then it is going to be a bit more expensive than just buying a complete key from ebay.
            If you do have the master key, then it will be cheap to do.
            Prados usually comes with 2 master keys (black with 2 buttons) and a valet key (grey with no buttons).
            Note that there are also 2 versions of the key. It has to do with the transmit frequency. Make sure you get the right one.
              Yes thats right, no buttons & plain black.
              I rang a Toyota dealer & using the VIN No of the car he told me they could do a remote key with buttons but he couldn't see that it came with just a plain black key, which is a worry.
              I also called Amalgamated & he quote $185 for one with buttons, I'm presuming this is programmed, he can also do just another black key for $99.
                So did you just pay the $37ish & then the cost to cut key & programme yourself? It states on their ad you can open the key up & check the number but this key can't be opened.
                  Yes, but my old one had the buttons. The casing was falling to bits and held together with superglue.
