Hi Guys i finally bought a 120 on the weekend and was hoping for some help,
Ive just purchased and 2006 120 series GX Limited Petrol ( 1 above the pov pack!)
and the heaters not heating , wanted some suggestions as to what it might be. Aircon working fine , nice and cold, as i rotate the cold to hot knob , it just blows room temperature air.
I pull the dash apart and i can see the lever behind working , I even looked at the side of the driver foot well and can see the lever rotating and functioning of the blend door!
just no heat!
I check the heater 50amp fuse under the bonnet, and I can feel the Heater relay activation in the same fuse box,
any suggestions?
just no heat!
any suggestions?
