Caution!! This is illegal........ The driver cannot be in view of a screen showing video whilst the car is in motion. The reasult of this will let driver view the video while the car is in motion. Moderator can remove this post if you think the content is not apporiate..
Finally got it going. Lots of muck around to get it to display video without using the reverse input. For those with Model 26028 there is 2 set of cables you need to modify to have it display video.
The first one is the blue connector which from factory is used to input the AUX sound. There is a resistor on that cable which tell the unit what kind of input it is. The one from the factory tell it is AUX. (Think factory is 50Ohm don't quote me on this.....). By changing the value of the resistor, the AUX will turn into VIDEO. I have not figured out the resistor value yet, but I found a cable with the resistor which works.
Once you get video instead of aux, here comes the next problem. The video screen is blank, which you need to modify another cable to ground one of the pins to have it displayed.
Here is some pics.....
Here show the AUX input is now changed to VIDEO
You can even change aspect ratio on the video.
Here is what happens when you hit the audio button.
The screen shown is blank because I have not connected the IPOD to it. I tried it, it works wonderfully!
I post back once I work out what the resistor value is.
