I've got a SWB Prado 120. Installed Fox 2.0 Factory rear struts that allows for up-to 3" lift. For the spring I installed the OME spring. Two questions to the experts:
1. When the axle is fully articulated the springs drop from their places (the SWB doesnt have the hollow rubber cone that holds the spring in place). Does it mean I need a longer spring do to the shock being longer? I dont want a higher lift than 2". How to choose the correct spring in this case (long enough not to drop out, soft enough to give 2" lift)?
2. I think the fox strut in the closed position is longer than the OEM strut. Does it mean I need to put spacer on the bump stops to avoid the strut bottoming out ?Where do I get such spacers?
