Steering wobble!
  • Steering wobble!
    G'day PP.
    I have been battling with this for a while now and I am getting sick to death of it, first off, a little info on the car:
    2009 KDJ120, 165,000kms, hardly been used off road, more a daily driver, I bought it off the old man in law about a year ago.
    The problem has remained with the car since I bought it.
    I get light and rapid steering oscillations between 85-100km/h, on and off but definitely more on than off, accelerate up past 100 and they almost vanish.
    The steering wheel is obviously oscillating but it can very lightly be felt through the car also.
    Too long; didn't read - (long version at the bottom)
    Things I tried:
    - each tyre rotated with spare
    - ceramic balancing beads installed
    - 4000klm done on tyres
    - new tyres fitted
    - 2 inch lift kit done, all joints/bearings seem OK
    - in that order
    It feels like an unbalanced wheel but I believe I have eliminated the wheels/tyres from the equation, I would still like to try a 'known good' set of wheels whenever I get the chance though to fully eliminate them.
    I'm at the point where I am ready to just start replacing stuff and see what happens but I don't really know where to start?
    I am thinking of putting a new set of wheel bearings through straight up as they don't look like a mission to do?
    Other than that, new CVs? Could it even be something on the back wheels??
    I am a skilled enough mechanic, have done an engine swap, diff rebuilds and transfer case overhauls, etc so I don't mind getting my hands dirty
    Open to any and all suggestions!
    Cheers!
    The long version if you can be bothered to read my rambling
    At this point, the car is dead stock.
    When I first noticed the oscillations, I rotated every tyre around with the spare one by one to see if the issue was related to any particular wheel, did not notice any change.
    I went to my tyre guy and had ABC ceramic balancing beads fitted, a product I had had very good success with on my previous cars.
    I did not notice any change after they were fitted.
    I then took the car on a 4000km trip (pre-planned, didn't have time to fix the issue, just the way things had to go) not long after buying it during which I would sometimes get violent oscillations around 80km/h.
    After getting home, I spoke to my usual tyre guy about the issue and he ran his hand around my old(ish) tyres and told me they've worn unevenly and need replacing, I was looking for an excuse for new tyres so I just went for it anyway.
    So a new set of 265/70R17 KO2s were fitted and the balancing beads transferred across.
    The problem seemed to go away for a good couple of months but then gradually returned, albeit about half of the severity.
    I then fitted a 2 inch lift, Tough dog shocks and king springs, during the install I paid very close attention to bearings, axles and ball joints looking for all the usual suspects but found nothing out of the ordinary.
    Again, after the lift I noticed no change.
    And that brings us to today!
    Could be a loose wheel bearing may need to be tourqed to spec
    or rim buckled ? I had these issues but with my 80 series solid axle so diffrent was panhard rod bushes
      Steering ball joints, steering rack, steering rack bushes...
        Not running BFG tyres by any chance are you? If so, there's likely the issue. Mate of mine sells them and a huge number have balance issues.. Google it, plenty of cases out there.
          BFG KO2s But I don't believe its the tyres as I had the same problem before changing tyres, still, I would like to test a full set of wheels to be sure.
            Yeah I have been paying close attention to those bits, I think I may have to pull down the steering components and have a very good inspection.
              Ask the tyre shop to take the tyres off and put the rims only on the balancing machine. See how much weight is needed and if the rim is running true.
              Find a tyre shop that knows what they are doing. I have 265/70/17 Mickey Thompson ATZ P3/ The tyre/wheel combo weighs 46kg. Most of the big tyre chains say they can balance a heavy 4WD tyre but can't.
              one of my rims has a slight buckle but can be still balanced out of you find the right tyre shop.
                BFG and K02 very very well known to have shit balance and wobbly issues..
                  Try a different set of wheels on it if you can borrow a set, or swap front to rears and see if it exists.
                    Where are you located? Australia is a big place.
                      G'day PP.
                      Things I tried:
                      - new tyres fitted
                      - in that order
                      Cheers!
                      I don't know if its related to the earlier Prado but my 2015 had steering wheel wobble. It was frustrating. I did everything you did.
                      I complained to Toyota and after getting "angry", some people in white suits from TMC Japan flew over and took my car for eight weeks.
                      They discovered that there is a problem in the drive train and issued a mod for manual prado's to add a dampener to the front end at a particular joint (I'm not tech savvy so can't tell you what its bolted onto but I can share a picture).
                      Anyway, the wobble went. I also found changing tyres helped enormously from the stock ones to Coopers.....the combination saved my sanity!
                        Perth, south of the river.
                          If you were near Brissy I could help you out with some alternate wheels/tyres for a test. Too far for a road trip!
                            Fair call! appreciate the offer though!
                              Interesting, I did a little bit of reading and it looks like a few people are having problems with balancing them.
                              Will be dropping into my tyre shop tomorrow arvo and seeing if he can run them up and check the balance.
                              Its just odd that my old tyres seemed to have exactly the same issue is all, possible that they and the new set are as bad as each other I guess... =/
