OME 889 coils in prado 120
  • OME 889 coils in prado 120
    HI Guys,
    I wonder have anyone fitter OME 889 coils in the prado 120;
    400mm length with spring rate of 260lb/inch;
    Its actually a rear spring of the 150, but is only 10mm longer that the 895 with the same spring rate
    Thank you
    Guys have anyone fitted coils larger than 390mm in length in the rear?
      I fitted OME 898 coils to the rear of our GXL 120 series in June 2016.
      These were also put in with the coilrite air bags that I had in the previous coils (also OME)
      80 series Landcruiser shocks got bolted on also for longer open length = more droop.
      Troy
        Troy
        Thank so much exactly what I wanted to know.
        Did you use standard 80series shocks?
          OME Nitro Charger 60020 Shocks.
          Carrying 40ltr Engel full time on slide and cargo draw with tools and recover gear etc.
          Sorry for the delayed response.
          Cheers Troy
