Hi.
I was checking my 2003 TD Prado suspension the other day and noticed the rear shock absorbers are "loose" in the way that I can rotate them with my hand. when I say rotate I mean in the axel parallel to the length of the shock absorber I can even see the upper nuckle rotating also. I am thinking buying new upper bushings and install them but first I would like to hear opinions whether this is normal behavior or the bushings are definitely wear.
Thank you
Thank you
