Front sway bar links
with 130k on the STD suspension you should be replacing it. heaps of sway bar links on Ebay
- 1 like
Ok, I'll elaborate.
Should I replace all of the bushes and the ball joint, and test the springs/shocks, because they're all likely to be on the way out too?
Or is replacing the sway bar links as simple job to keep me on the road?
I've got 130,000 km on the clock.
Leave a comment:
So a quick check under the front end this evening, before we head away for the weekend, has revealed 2 deteriorated sway bar links.
Any tips and tricks on where to buy from, which brand, what I should check/replace whilst I'm going to the trouble???
Tags: None
Leave a comment:
