Yokohama GEOLANDAR A/T G012 275/65/17?
  • Yokohama GEOLANDAR A/T G012 275/65/17?
    What can you tell about new GEOLANDAR A/T G012? And whether it is possible to use the size 275/65/17 on factory disks and suspension?
    Originally posted by raymastephenson
    I would also like to know if these are legal fit, being 275 not 265 to fit on standard rims and if the 14mm difference in diameter is a problem with diffs,also will these fit under the spare tyre cover ???
    Yes 275 are legal on a 7.5 rim no hard cover won't fit.
    2006 TD Grande
    ARB Winch Bar. Rallye 4000's
    GME TX 3400
    BF Goodrich 265/65/17
      If I understood you correctly, the 275/65/17 can be safely set and nothing will be hurt and rub? And if it so, has someone photos to compare factory 265 vs 275 to see how big visual difference?
        I have 275/65-17 AT22 Grandtrecks (ex Landcruiser) on mine and they fit fine... not even close to rubbing anywhere. I actually think they look better being slightly wider. With the overall diam being a little bigger, the speedo should be just about spot on.
        cheers, Rod
        2005 VX V6 4.0L, Pearl White, Sovereign bar, nitestalker spotties, Tow Pack, Headlight & Bonnet Protectors, radiator bash plate, sandgrabba mats, cargo mat, DVD in headrest, radiator insect screen,
