So we've had the Red Adventure Wagon over 6 months now and are starting to think about broadening our 4WD horizons a bit. I have no documentation but have a feeling our suspension may have been lifted at some point, certainly the shocks (and I suspect some other things) have been upgraded at some point. Is there an easy way to tell, even just a low tech height measurement, that can tell if it's been lifted? It's a 2000 Prado 95 3.4L V6 GXL.
How to tell if your Prado has been lifted
Measure wheel centre to guard straight up. I don't know what the figures are but plenty of guys know off the tops of their heads what the numbers should be.
Also search ride height on here, but use google to do it.
So go to google, type in your search query and then put siteradopoint.com.au at the end so it limits its searching to the forums only (because the forum search is junk).
Brilliant thanks
- 1 like
Originally posted by 'Dan' View PostThen it will be lifted.
The common measurement is done from bottom of rim to guard. There are plenty of numbers on PP if you do a search.
- 2 likes
I did as suggested and in the end it matches almost exactly the stock height for a 95 GXL in this fantastic guide https://www.pradopoint.com.au/forum/...-upgrade-guide
Thanks very much for your help with this guys
Yeah good question , until recently i thought mine was lifted a bit . but no ! to my surprize its all original with the original struts .
yes from glen-ep 2010 this post tells all .. im gonna out and measure mine now.
Original GXL
Front Suspension: Originals
Rear Suspension: Originals
Tyres: Original 265/70R16 (30.6")
Load: Unknown (various sources)
Age of suspension: Many years
Rim-to-Flare measurements:
- Front: 730 ~ 745 ~ 753 mm
- Rear: 725 ~ 740 ~ 755 mm
Articulation measurements: Unknown
2" suspension - OME medium - 6 months
Front Suspension: OME 2881 coils with 90004 struts
Rear Suspension: OME 2890 coils with 60028 shocks
Tyres: 265/75R16 Mickey Thompson MTZ
Load: Steel bull bar. Third row seats removed. Toolbag in the rear.
Age of suspension: Maybe 6 months
- Front right/left: 776 / 776 mm
- Rear right/left: 794 / 798 mm
- Front left droop / right compressed: 820 / 677 mm = Front travel: 143 mm (~5.5")
- Rear right droop / left compressed: 1026 / 572 mm = Rear travel: 454 mm (~18")
Owner's mod page: http://www.pradopoint.com/showthread...ting-broken-in
2" suspension - OME heavy
Front Suspension: OME 882 coils with OME N91S struts, Sonoran Steel front diff drop
Rear Suspension: OME 892X coils with N86 shocks
Tyres: Originals
Load: Front winch with minor bar work. Third row seats removed.
Age of suspension: 1 month (expect further sag)
- Front (left / right / avg): 808 / 805 / 806 mm
- Rear (left / right / avg): 820 / 811 / 815 mm
- Front (extended / compressed): 890 / 690 mm = Front travel: 200 mm (7.9") * Not confirmed, but with this kind of figure, the sway bar was probably removed.
- Rear (extended / compressed): 990 / 670 mm = Rear travel: 320 mm (12.6")
Owners's mod page: http://www.pradopoint.com/showthread...t-installation
- 1 like
