UHF Spring Based Aerial - Which is better; fibreglass or Stainless Steel Whip?
    winniliss
  • winniliss
    replied
    The ZCG ZN3-77-11 black (6.6dbi 1.2m) antenna has really good reception. I was travelling through small hills and flat ground and was listening to a grader driver 50km away that had a standard metal whip about 600mm long. The main thing you need to ensure is the antenna is above the roof line and clear of any metal obstruction. The icom Pro 400 is of commercial quality and as a result has good transmit and receive properties.
    Winston.
    Leave a comment:
  • rob_macca67
  • rob_macca67
    replied
    Guys....
    What's the best "allround" Tuned aerial to get..... 4.5Db or 6Db, etc ? I know the the bigger the better, but for allround (flat terrain; hilly, etc) would the 4.5Db be the best overall one to get ?
    Rob
    Leave a comment:
  • wooley
  • wooley
    replied
    I've broken a number of 4705/6 whips, but they're still the longest lasting aerials I've owned.
    I find the aerial cable inside the fiberglass detaches and causes problems.
    Still don't think you could find a better aerial though.
    Leave a comment:
  • AJ120
    Out of control poster!
  • AJ120
    replied
    I must say I am pretty happy with my 2 GME 4705 antennas, they don't vibrate nearly as much as the old thin fiberglass one. They took a real pounding down a horribly overgrown track to Hanging Rock in Rudall River NP, and both stood up to that. Not to mention the 4000kms of dirt outback roads including the Gunbarrel hwy.
    Leave a comment:
  • winniliss
  • winniliss
    replied
    I got mine from ARTC (Amateur transceiver radio center) in Syd but they have since closed down due to Les having poor health. I saved about $100 with the radio and the 2 antenna's and the shipping compared to Prestige.
    Leave a comment:
  • D4D
    Addicted PP Member
  • D4D
    replied
    $314 including shipping from Prestige
    http://www.prestigecom.net.au/ZCG-66...ullbar-Antenna
    http://www.prestigecom.net.au/ZCG-Hi...te-Antenna-Top
    From memory the Stinger is $350-400
    Leave a comment:
  • rob_macca67
  • rob_macca67
    replied
    Once you buy the spring, the dipole and the stubby antenna it works out about the same price as the Bushcomm.
    OK.... I was thinking that the Bushcomm would work alot more expensive than what u suggested
    Leave a comment:
  • D4D
    Addicted PP Member
  • D4D
    replied
    Leave a comment:
  • rob_macca67
  • rob_macca67
    replied
    Thanks, this is going to be my next upgrade. I would prefer the Bushcomm Stinger but the ZCG allows you to fit the stubby antenna around town.
    Plus there would be a fairly big price difference I would assume ???
    Leave a comment:
  • D4D
    Addicted PP Member
  • D4D
    replied
    Originally posted by winniliss View Post
    106cm without spring, 118cm with spring.
    Leave a comment:
  • winniliss
  • winniliss
    replied
    Originally posted by gumboot View Post
    Winston
    I noted you are using the side wing on the ARB bar to mount the aerial.( My ARB bar vibrates a fair bit)
    How much vibration do you get on the 1.2metre aerial with that ZCG spring mount?
    Robert
    Stuff all. Even at 130km with road trains passing. The 2m antenna I get some oscillation.
    Hey Winston, what's the total height of the 1.2m with the spring base included?
    The longer one is 197cm without spring, 209cm with spring.
    Winston.
    winniliss
    Leave a comment:
  • D4D
    Addicted PP Member
  • D4D
    replied
    Leave a comment:
  • gumboot
  • gumboot
    replied
    I use an Icom Pro 400 (up to 25w output) and I use 2 antenna's - a ZCG ZN3-77-12 black (8.1dbi 2.1m) and ZN3-77-11 black (6.6dbi 1.2m).
    Winston
    Winston
    Robert
    gumboot
    Leave a comment:
  • rob_macca67
  • rob_macca67
    replied
    Originally posted by baggs71 View Post
    External wire around flexable whip ive noticed works...
    Internal tends to rattle if treated hard
    Stainless snap at the base...
    These are my experience only
    Unfortunately, this didn't work for me.....
    Leave a comment:
  • baggs71
    Inactive member.
  • baggs71
    replied
    Leave a comment:
