How many kg winch extension strap do I need? 4500? or bigger
Winch ext strap size
Winching doesn't give shock loads like snatch straps, more a gentle constant pull. So 4500 would do for a standard prado and never use it snatching. I run 10000 myself however as its what I found at the time at the supplier I used. If you feel you may ever need to use the extension for a snatch (And you likely will) I'd get higher rating. I recall once having to snatch a Patrol out that drove onto a sloppy salt pan.. We had 12 x 20 mtr winch extension straps on him as you couldn't get a car near him.
Originally posted by Piggy View PostWinching doesn't give shock loads like snatch straps, more a gentle constant pull. So 4500 would do for a standard prado and never use it snatching. I run 10000 myself however as its what I found at the time at the supplier I used. If you feel you may ever need to use the extension for a snatch (And you likely will) I'd get higher rating. I recall once having to snatch a Patrol out that drove onto a sloppy salt pan.. We had 12 x 20 mtr winch extension straps on him as you couldn't get a car near him.
Winching load will vary depending on surface, depth of bog, incline and free movement of wheels. Regardless of which WLL you choose consider a winch extension rope instead of strap. You can't use Strap through a pulley. Use of a pulley or multiple pulley blocks also reduces the load on the winch.
Originally posted by whynot12 View PostWinching load will vary depending on surface, depth of bog, incline and free movement of wheels. Regardless of which WLL you choose consider a winch extension rope instead of strap. You can't use Strap through a pulley. Use of a pulley or multiple pulley blocks also reduces the load on the winch.2018 VX Prado
