Removing spare tyre cover permanently
  • Removing spare tyre cover permanently
    Hi! I’m hoping to remove the rear wheel cover permanently on my Prado 150.. I’ve been researching about a spare tyre spacer??? Just wondering if anyone can tell me what I need and where to find one.. thanks
    Plastic/nylon bread board. Drill holes to suit.
      I have a Kaymar spacer it gives almost 2 inches extra.. almost to much I feel? Feels like it may flex a little to much on the door also..
      not sure what size tire your going ? With a 265/70 most brands it doesn’t touch
      I have falken wildpeak at3w and they are slightly wider and just touching and seems like it would touch the when going over bumps and corrugations that’s why I got the spacer
        So with the 265/65 or 265/70 I should be ok to just remove cover and the black thing behind it?
          Yes
            I have a second set of 265/70/17 Yoko GO15 AT 121S (extra load) and they touch so I fitted a 4mm spacer (nylon) for clearance. I was able to reuse the original mounting bolts.
            I think it depends on the load rating as too whether they will rub or not as well as LT construction or not.
            Lee
