2019 VX towbar
  • 2019 VX towbar
    I need a towbar on my 2019 VX because I'm planning on getting a camper trailer soon. Is there any reason why I should look for aftermarket ones, and not just getting Toyota to fit one at the next service? Any advice on what to get appreciated.
    Only if you can get a reputable brand fitted for cheaper I can't think of any other reason. Note to option for a flat pin trailer plug as most camper trailers will be this, and I think Toyota might be round as standard.
      All right, thanks for that! Toyota will fit it at my next service in three weeks. $1200 for parts and installation (with flat pin).
      Cheers!
        Hey randog,
        I'm not sure where you are but these from Wynnum Towbar Centre, 2 Burke St Wynnum, are about $700 fitted from memory
        Phone: 07 3893 0411
        I'm not affiliated in any way, just a happy customer.
        We now offer CLASS 4 heavy duty towbars specifically designed for the NEW TOYOTA PRADO 150 Series. Rated at 2500 kg there is no cutting of the bumper required, unlike the standard Toyota towbars which require a section of the bumper to be cut out. This leaves your vehicle intact should you wish to remove the tow point at a later date.
          Thanks! Wynnum is a bit out of the way, even though I'm only down on the Gold Coast. I've contacted a couple of places more locally now just to compare prices and see if it's worth while or if I am better off getting all done while the car is in anyway.
            Originally posted by BNEGXL View Post
            Hey randog,
            Phone: 07 3893 0411
            The post sometime in 2017 Prado 150 Automatics are rated for 3000Kg so I would hope they have a rerated towbar for 3000Kg now.
            I had the toyota towbar fitted but had to change the standard flat 7 pin to large round 7 pin to suit my requirements.
            Prone
            2018 Prado 150 VX Auto
              Just got a reply from one of the local shops down here on the coast:
              03223RW Hayman Reese Towbar
              3000/300kg towing
              04826 ECU
              04816 Smart Click wiring
              $855 fitted and wired
                them Wynnum bars look LOW
                  The Wynnum towbar is no lower than the Toyota towbar, the Toyota bar is cut into the rear bumper and also has a crossbar that hangs underneath the bumper as well.
                  kartal escort
                  sex vidio
