Can anyone enlighten me as to whether you can buy a cruise control kit for a 2018 150 GX manual, either from Toyota or after-market? I have googled but not seen anything.. Thank you!
Cruise Control Kit Retro-Fit?
I have ordered all genuine parts for this; switch, two wires, clutch switch etc... If anyone can help me with two questions? 1. is the wire for the clutch switch already at the location, as I cannot find it on th parts catalogue? 2. Do I connect anything to the ECU or does the new wire 84633-48020 just plug in locally in the steering wheel hub and that is done? Thank you!
It depends of the market, I had to connect the swtch to ecm, in other markets the wires are already on the steering column. Mine is petrol 2.7, the difference is just wich pin in the ecm is for the switches. There is a webpage from toyota where you pay like 5 dollars and give yo acces for any diagram needed for 1 hour
For those following this. The genuine parts arrived from Amayama and I installed the switch (8463234011) and wire (8463348020) and the connector plug is already existingand hey presto, it works as it should . My 2018 GX manual already has a clutch switche fitted so that was not needed. Also no T30 screws on mine, but 2018 later have 3 clips inside the steering boss to unlock the airbag module (always disconnect the battery for 10 mins first and press the brake after to discharge).
Anyway, job done and happy motoring to all.
