Damaged Windscreen Wash Bottle 2014 GXL D4D
  • Damaged Windscreen Wash Bottle 2014 GXL D4D
    Hi All
    Did the dumbest thing today. Went to drill a hole to enable cable tie if the plastic inner guard shrouds together to stop them rubbing the tyres when full lock over bumps (non lifted and larger tyres) and I managed to drill a hole through the windscreen washer bottle. The hole is right at the bottom to make it worse. Tried the old self tapper with rubber and abit of silicon, no luck. I bought a repair kit from Supercheap but the hole is too low. Would need to take the bottle out to repair. Any clues how to get it out? The plastic plugs holding the plastic inner guard shrouds are a mongrel to remove, any clues on removing them without breaking them? Or, where can I get a replacement bottle?
    Dummy with a Drill.
    Canít you just squeeze a bit of sikaflex into the hole ? Drain it first.
    2018 VX Prado
