Has any body removed the master cylinder on thr prado 150? I have a leaking shaft seal,dripping on floor mat. Is it a big job. I was thinking I could save some labour then take the master cylinder to brake specialist for repairs.
Brake Resivour Removal
Originally posted by RTH67 View PostHas any body removed the master cylinder on thr prado 150? I have a leaking shaft seal,dripping on floor mat. Is it a big job. I was thinking I could save some labour then take the master cylinder to brake specialist for repairs.
Re changing it out, its a simple job and all up took me just over an hour and had never done it before. The bleed process is just like normal - you DONT need any special ABS modulating tool to get the air out of the ABS unit, just have the car running while bleeding.
