Bleeding Brakes - strange behaviour
  • Bleeding Brakes - strange behaviour
    Hi folks -
    So doing a Brake fluid bleed - with ACC on...
    Rear Brakes - on opening Nipple - the pump detects loss of pressure and pumps fluid through - easy :-)
    Front Brakes - open nipples and nothing??? Apart from a little fluid coming out.. but no pump kicking in to help...
    Is that normal??
    2010 GXL V6 - Point Cook, Victoria
    Gavin
    Normal behavior. For the front, get a helper to pump the pedal once and hold, open & close the bleeder valve. Then repeat. Don't let the pedal sink to the floor when the bleeder valve is open.
    My Rig Build up
    sigpic
