Can anyone confirm if the hose connection in the pic on the top drivers side of the radiator is where hot transmission fluid from the auto trans enters the OEM trans cooler ? Vehicle is a 2019GXL with a 2.8L GD motor.
Transmission cooler inlet or outlet ?
Originally posted by gxl_d4d View PostYes, top hose is inlet, bottom outlet.
I've found the top hose to be significantly cooler - indicating it is the outlet, and the bottom hose significantly warmer - indicating it's the inlet.
- 1 like
