Hi, I have a 2010 GXL and would like to upgrade the bulbs in the headlights to something a bit brighter/better without having to change the headlight body as such. What's the best option that people are going for ? Any ideas would be great cheers
Upgrade GXL headlight bulbs
Originally posted by Goggo View PostHi, I have a 2010 GXL and would like to upgrade the bulbs in the headlights to something a bit brighter/better without having to change the headlight body as such. What's the best option that people are going for ? Any ideas would be great cheers
I'm not really sure what bulbs are used in the 150, so I'm just going to show you the H4 bulb used in the 90 and the 120. Brand and Light output is the same... just a different shape... maybe.
The bulbs are often rated as +60 or +100 so on and so forth. The higher the number, the higher the percentage of supposed light output.
From Narva - Available from virtually every autopart store around.
http://www.narva.com.au/products/bro...ormance-globes
From Philips - Available from most autopart stores. Standard stock in Autobarn and Repco
I personally use these guys. They are 130+
http://www.philips.com.au/c-p/12972X...n-plus-halogen
But you also have...
+30, +50 and +100.
Also available is the line-up from Osram
Night Breaker Unlimited 110+
Silverstar 2.0 60+
Hope this helps!
I previously had Osram Night Breakers in and now have Philips bulbs. I would have the Osram bulbs anyway over the Philips. Seemed to put out a lot more light. As soon as the Philips cark it I'll be going back.
Sent from my SM-G900I using Tapatalk2013 [COLOR="#006699"][B][SIZE=2]Blue Storm[/SIZE][/B][/COLOR] D4D 150 GXL Auto, Opposite Lock Bullbar, Safari Snorkel, GME 3345 UHF + AE4018 Antenna, HR Tow Bar, TG150, HD Rhino Roof Racks, Foxwing, Dual Batteries, C-Tek DCDC Charger, ARB 47L Fridge, ScanGauge II, Internal Fishing Rod Storage, X-Ray Vision HIDs and LEDs, New PP Sticker.... [COLOR="#808080"][SIZE=1][/SIZE][/COLOR]
I too prefer the osram night breakers over the philips extreme visions. Keep an eye out for the amount of blue filter on the bulb. As Starbuck above says, more blue makes for a whiter light, but flipside is it reduces range and output.
Try driving at night in the rain with a bulb featuring 'maximum legal blue'...like having keyring torches for headlights.My white GX auto build thread - [URL="http://www.pradopoint.com/showthread.php?35075-Early-s-150-TD-Prado"][U][B][COLOR="#0000FF"]clicky[/COLOR][/B][/U][/URL]
Thanks for all the help guys, sounds like the Osram ones are the go. Where is the best place to get them and what sort $$$ are they?Last edited by Goggo; 28-12-2015, 06:04 PM.
Ebay is the best price I have found. Start at about $45 for a pair.
http://www.ebay.com.au/itm/161418316661?redirect=mobile
Any one have any before and after evidence that these bulbs are better than factory. I find most third party bulbs to be the same, or worse and fail within the first 12 months.
Cheers.
Sent from my iPad using Tapatalk[CENTER][B]-=2014 GXL D4D Auto Graphite, Firestone Airbags, ARB/Optima D34 Dual Battery, ARB UVP, TJM Airtech Snorkel[/B][B]=-[/B]
[/CENTER]
I did a quick comparison on the garage, 1 Night Breaker and 1 OEM. Did appear to be considerably brighter. Also pulled up next to another 150 (presumably standard) in an undercover carpark and I was quite impressed with how much brighter my Night Breakers were.
Hey Symo. I took before and after shots of when I rewired my 90 but I also rewired them directly from the battery through relays and picked up a further 2 volts at the lights for extra power. So it's hard to determine from that how much extra the bulbs really added as I went from 10.4Volts up to 12.2Volts at the bulbs... 20% power increase.
I was also using Philips 130s
I wonder about the recent interest in bluish light for driving. It is well documented that blue is one of the worst colours (frequencies) for the human eye to focus especially at night when the pupils are at maximum dilation. Humans have evolved with eyes most sensitive to yellow/green - which is why blue light is sometimes linked to eyestrain and fatigue if used for long periods. Has anyone found they enjoy using lights which produce light near the blue end of the spectrum?
