12v outlet wires
  • 12v outlet wires
    Hi guys
    Re. 12 volt outlet in center console (between front seats). Prado 150 late 2013 (update)
    I cant find my multimeter. Can anyone please tell me which is positive and which is negative (green and white with black stripe). Guessing white with black stripe is neg.
    Prado 150 with lots of stuff on it
    you are correct , the green wire is positive , White / Black is negative.
    Just under the white connector clip you will see a small L shaped black wire , that is a fusible link which melts if you draw more than 10amps through the socket.
      Thanks Nudgebar. So 2 x 3.1A USB chargers piggybacked onto those wires would be okay then.
        All done. 2 x 3.1A USB chargers installed in switch blank. So much neater than the cigarette USB charger plug.
          Nice!
          Where did the USB outlet come from?
            Originally posted by rpn View Post
            Nice!
            Its from "Air On Board" in Research, Victoria.
            http://www.aironboard.com.au/store/
            I've got a couple driving light switches from them also.
              Is the USB port 3.1A total or 2 * 3.1Amp? Most seem to give you a 1Amp port and a 2.1Amp port which totals 3.1 Amp across both ports. Sneaky marketing.
              Edit: I checked the site and it is 2 * 3.1Amp which is great.
              http://www.aironboard.com.au/store/p...itch-size.html
                No itís total
                2.1 and 1
                I checked with AOB via email
                cheers
                mike
                White 2010 gx diesel auto, bilstein shocks 50mm lift king springs, tjm steps, warn 9500, lt265-65-17 bfg atko on steel rims. Racor 230R10 filter
                Adelaide based
                  Originally posted by reddevil25 View Post
                  No itís total
                  2.1 and 1
                  cheers
                  mike
                  Ok. I wonder which one is which? they are not labeled.
