HI Beam pick up
  • HI Beam pick up
    Has anyone wired up driving lights to a 2018 prado or a prado with led headlights?
    Where did you find a Hi beam pick up point?
    Lightforce sell an adapter plug for picking up the high beam.
      Other people have said they're using the genuine wiring harness as there weren't any aftermarket options available yet. Part number is PZQ59-60140 and Toyota price is $132.11
        Is that part number out of the genuine driving light kit?
          That's just the wiring harness.
            Does anyone know the Lightforce kit part number?
            or has anyone been able to just patch into the original wiring?
              The electrician that i went to was able tap into the original wiring however the only problem is my light bar can be switched on by pushing the high beam lever forward without the lights being on and the car running.
                The new Prados run CanBus on the headlights, so the genuine harness is the way to go
                  Wouldn’t the canbus only be an issue if you picked up the wire at the switch? Thought if you picked it up at the light you’d be ok.?
                    I was trying to find a separate fuse for the high beam. I found two under the bonnet. One does both LH lights H-LP LH-LO the other does both RH lights H-LP RH-LO. Then there is H-LP HI which does both RH lights again.... More confused than ever
                      Is the Toyota harness for spots or can it be used for a light bar
                        I doubt it would matter freddy, worst case scenario youd have a spare light output if it was designed fir a pAir
                          Toyota harness can be used for any light/s. Apparently it is rated for 2 x 55W lights to so you need to check your maximum load. LED spots can be over 200W in total.
                            ARB make a set of instructions for this that is intended for use with their own looms but I adapted them to work with another brand. It includes pretty much all parts needed, wiring diagram, instructions of wires to tap into etc. ARB Part No: 3789808. I have a copy on e-mail but not sure of their rules regarding sharing copies.
                              Just ran into this same problem, my auto electrician is trying to find out from Toyota where he can get the pickup from, the genuine wiring harness must pick it up from somewhere, we have light bar, switch and wiring fitted just looking for the pickup now. He said he can get it from in the cab but I think ill end up with the same issue as Two89wabove with the light bar turning on when it shouldnt.
                              Any help from those that have done it would be appreciated
                              2009 GXL 120 Series [URL="http://www.pradopoint.com/showthread.php?28535-Grims-2009-120-GXL"]Grims Rig Build Up[/URL]
