Reading some of the alternator feeds and I'm getting nervous. I had somewhat imagined that the 150 series Prado would have a higher rated alternator than my previous 90 series. Well the 90 series alternator lasted 230.000kms so all good. I think it would have lasted a lot longer if I hadn't set out trying to get more charge into the secondary battery. You could observe the voltage droop as system load and under bonnet temperature increased, in a way it appeared self regulating. Just after engine start it would sit around 14.3V, then could go as low as 13.6V. At 230 000km I swapped over to a 20A DC to DC charger for the secondary battery and I think it stressed the alternator out especially when driving with high beams and driving lights. In the end two diodes failed and I moved to an aftermarket replacement as I couldn't get a diode bridge for the Denso and Toyota quoted 6 to 8 weeks for a new complete alternator. The aftermarked alternator held 14.4V hard and lasted two weekend camping trips, then regulator failed and voltage went high, but luckily no over voltage damage to anything. Got a replacement under warranty and shortly after found a Prado 150 I really liked and traded up. I'm yet again make all the same observation that the DC to DC secondary charger really sucks the energy out of the alternator, the voltage drooping doesn't help, the charger will draw just even more current. Add to this another DC to DC unit in the caravan that we now have and one will understand some concern on my side now. After a couple of days camping you could have a combined capacity of some 200Ah that will demand charging through two DC to DC chargers, and that setting off into a hot day with aircon running creating high under bonnet temperatures. I'm not a believer of reducing the alternator sense voltage feedback with a diode, it is in my opinion interfering with the self regulating droop that would work with a standard car. All is still working on the 150, but what options do we have in Australia? I can find mainly two aftermarket drop ins, but based on the experiences made with one that was readily available for the old Prado I'm not so confident doing the same on the 150. Highest capacity seems to be 130A. This is still not great when dropping winching into the equation as that puts tremendous loads on an alternator when batteries start to go down. Diodes need to be quite robust. I have seen some high current (200A) mechanically compatible options available in the USA, but nothing locally.
Does anyone have experiences that they can share specifically in regards to reliable alternator upgrades? Did someone get something from overseas? Or just anticipate failure and take a spare? Quite dead weight to carry so, hence thinking overrated serviceable quality unit with adequate margins. I assume that one would also need to upgrade the main wire from the alternator and fuse-able link to the main battery terminal.
