Hey guys,
noob here so go easy. if this needs to be in a different section let me know.
So I just bought a 2010 Prado 150 GXL which has a dual battery setup and I have some questions.
First off current setup:
Primary battery seems to have the standard in car power accessories (12v 220v plug) , additional spotlights, and a Anderson plug at the rear
secondary battery is connected via a red arc SBI12 and only has the uhf connected to it
I deduced that the Anderson plug in the rear is connected to the primary battery by disconnecting the positive terminal on the primary battery and confirming that the Anderson plug has lost power.
I am trying to understand why anyone would have the Anderson plug connected directly to the main battery in this type of setup?
ideally in my mind I want the Anderson plug connected to the secondary battery so I can run any accessories when the car is off and know that he redarc will cut the connection to the primary battery once it gets to a certain voltage. that way I don't have to worry about getting stranded and being unable to start?
i have attached a photo of what i plan to run any accessories on when the car is off and connected to the Anderson plug.
also attached photos of the red arc.
i am currently at work but if you need more photos let me know and i will take some tonight.
for what i want to do should i just rewire the Anderson plug to connect to the secondary battery?
