2nd fuse panel
  • 2nd fuse panel
    So I found a 2nd fuse panel on the 150.
    Under the dash, driver's side.
    You have to remove the under dash trim to even see it. Has micro fuses and they're extremely difficult to get at to replace.
    Can't imagine anyone ever doing this on the side of the road.
    Easy. Stand on your head! To remove fuses just use pointy nose pliers or there is a fuse extraction tool in the main fuse box near the battery.
      My extraction tool in the main box was for standard sized fuses, not the micro jobs. Had to use Mrs from her i30 when long nosed pliers couldn't grip the tiny fuse. I got there eventually but what a dreadful position to mount the thing.
